Re: Re: Re: getting discouraged / need help Farmalldan et al
Posted by farmalldan on March 26, 2002 at 11:33:49 from (64.154.26.248):
In Reply to: Re: Re: getting discouraged / need help Farmalldan et al posted by If I follow you / boog on March 26, 2002 at 10:08:33:
Yes, I think you've got it. Sounds like your friend's tractor is connected the same way. All fluid from pump into priority valve. Excess flow port feeds both Lift-all and flow control valve through a tee. "T" port on priority valve and return from steering motor both go to tank. The large line to your pump is suction and is essentially "tank", but you might consider connecting both to your Lift-all filler via a tee to insure no air is sucked into the pump. I am still a little concerned about your comment that the power steering worked briefly while the Lift-all rod was back and then locked-up. This causes me to suspect pressure on both sides of the power steering motor. Check that both return from power steering motor and "T" port on priority valve are open and not blocked under any circumstance. Fluid must flow from these connections unimpeded. If in doubt, temorarily stick them in the filler neck to test system function. Good luck.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
