Re: Bob M, other electrical guys...
Posted by Bob M on March 16, 2002 at 07:14:41 from (66.66.72.246):
In Reply to: Bob M, other electrical guys... posted by Steven@nd on March 15, 2002 at 18:27:13:
Steven - All of the ideas below will work, though with a couple of clarifications: 1 - Wire the Hobbs meter "-" terminal to the regulator GEN terminal. (Assumes you have a positive ground system - if your tractor is negative ground connect the Hobbs "+" terminal to the GEN terminal) The meter should run whenever the motor is running, even when the generator is not charging (3 or 4 volts appears at the GEN terminal even at low idle...) 2 - The pressure switch idea will work - though you gotta use a NORMALLY OPEN pressure switch (one that closes it's switch contacts when it senses pressure) for this to work. Note: Nearly all vehicle oil pressure switches are NORMALLY CLOSED - contacts close on loss of oil pressure. So you can't simply grab any old oil pressure switch and have this one work. 3 - Replace the stock magneto kill switch with a DPDT toggle switch. If you wire it correctly, no relay is required. I personally prefer #3...
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
