Re: three point conversion
Posted by Haas on February 17, 2002 at 17:03:19 from (129.37.117.118):
In Reply to: three point conversion posted by mark on February 17, 2002 at 14:49:16:
I don't agree with dave on the Box blade. The Super A 3 pt should easily lift a 4 ft box blade using the rockshaft for the 3 pt lift. With the 3 pt using the front rockshafts, you should be able to pick up around 500 lbs, and the 4 ft box blade should not weight that much. I have a 6 ft box blade and my Farmall C with the 3 pt hooked to the rockshafts will pick it up. Doing much work with the box blade might be another matter. You can smooth loose dirt, spread gravel and the like, but don't expect to do a lot of heavy dirt moving. As to the wood splitter, the low reservoir capacity may be a problem and you might have to add reservoir capacity. Saginaw County Tractor makes a block that bolts in where the hydraulic manifold bolts to the touch control that would inable you to hook up the wood splitter and use the Super A hydraulic pump. I've measured the pressure on my C and the max pressure from the pump is 1500 psi. You may get less if your pump is not in good shape.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
