Re: Brakes on my H
Posted by Michael Soldan on January 28, 2002 at 15:39:58 from (216.46.130.89):
In Reply to: Brakes on my H posted by Richard C on January 28, 2002 at 13:30:57:
Hi Richard, the first thing I would do is to stand beside thebrake pedals and pull each forward by hand...this will give you a feel as to how closely they are set...if one feels weaker to pull than the other you need to adjust...first on the brake pans at the bottom make sure those set screws are in snug against the brake lining..they won't go all the way in , just till they are snug...then remove the split pins and the pin on the bottom of the brake clevis, with luck the clevis will turn allowing you to lengthen or shorten the clevis , shortening increases brake drag, lengthening decreases brake drag. As for the noise you hear it could be rust, brake dust, but you could have a lining getting down to the rivets. Removing the brake pans(covers) is not hard and you don't have to take the brake arm off the side of the pan (it all comes off together as a unit) If there is oil and greasy looking material in the pan and around the linings you will need new seals behind the drums. Undo the stud on the end of the drum and with two screw drivers one on each side wiggle and pry and the drum should slide off the shaft exposing the seal. If this is the case give us a shout on the forum and I or others will be glad to help you in seal replacement..I've done two H's in the last year..easy to work on but takes some time too...good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
