Farmall Tractors Discussion Board
Re: 12 volt alternator
Posted by Mark on July 22, 1999 at 19:02:07 from (12.28.201.248):
In Reply to: 12 volt alternator posted by John on July 22, 1999 at 17:35:58:
I installed a single wire conversion on my H and it works GREAT! I didn't include an ammeter in my circuit(just left it out since the original is for 6 volt system). The single wire goes directly to the + (positive) battery terminal. Then you have to "shunt" the field, start the tractor and let it run for a couple of minutes to "activate" the one wire alternator (check your instructions that came in the kit or with the alternator). You can check voltage between the Positive and negative terminals at the battery and should get 13.6 to 14.2 volts for a properly operating alternator (bring the engine off idle or it won't be operating within range).
Post a Followup
: Re: Re: 12 volt alternator
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
