Farmall Tractors Discussion Board
Re: Replacing Belt pulley seal on Farmall H
Posted by Gene on June 17, 1999 at 17:40:12 from (208.129.170.89):
In Reply to: Replacing Belt pulley seal on Farmall H posted by The Red on June 16, 1999 at 16:49:00:
Helo red, It is simple to replace the seal in the belt pully, Remove all the bolts from the top of the unit, pick up the unit and lay it upside down on the work bench, cut a piece of thick gasket materal and cut a hole out just to clear the geer.
H old the gasket in place and use a small ballpene hammer and start tapping the edge of the unit, the gasket will cut as you tap along the edge. you can cut the gasket out then mark the holes and cut them out. apply gasket sealer to all sides and your done. Hope this helps Gene
Post a Followup
: Re: Re: Replacing Belt pulley seal on Farmall H
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
