Farmall Tractors Discussion Board
Re: Cub charging
Posted by Rick K on June 09, 1999 at 09:43:01 from (205.181.231.254):
In Reply to: Cub charging posted by Chris Bean on June 08, 1999 at 10:39:22:
Assuming that you have a regulator, and not just a cutout relay, a mechanical regulator works as follows...
There is one relay that simply opens when the generator is not putting out enough voltage to do anything. This prevents the battery from discharging back into the generator (which would actually turn the generator into a motor).
There is another relay that monitors the output voltage, and maintains the generator at fairly constant average voltage. It does this by opening and closing rapidly. The higher the percentage of closed vs open, the higher the output voltage of the generator. The contacts of this voltage regulator relay short the low side of the field winding in the generator to ground, causing current to flow in the field winding, causing the field winding to make a magnetic field, causing the generator output voltage to go up.
The last relay is the current regulator, which opens the field winding when the generator tries to put out too much current, so you do not burn anything up.
Post a Followup
: Re: Re: Cub charging
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
