Farmall Tractors Discussion Board
Re: Cub charging
Posted by Larry on June 08, 1999 at 20:12:02 from (206.228.213.86):
In Reply to: Cub charging posted by Chris Bean on June 08, 1999 at 10:39:22:
Remove the wire from the bat terminal on the regulator. Hook an ammeter between this wire and the bat terminal. At the field "F" terminal take a short piece of insulated wire with both ends stripped of insulation and mount one end of this stripped wire in with the field wire.(charge the battery and if necessary jumper to the coil in order to get the tractor running again) Once you are running at medium throttle momentarily short the wire mounted to the F terminal to ground while watching the ammeter. The gen output should increase. No increase indicates a Gen problem. An increase indicates regulator problem.
Post a Followup
: Re: Re: Cub charging
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
