Farmall Tractors Discussion Board
H Strainer Bowl and Charging Rate
Posted by B. Batty on June 05, 1999 at 18:52:39 from (205.188.193.162):
I adjusted the movable brush on generator for minimum charge rate but it still charges at about 16 amps at low switch setting and about 20 amps at high charge setting. The manual says the generator should be adjusted for a max. charge rate of 9 to 11 amps (hot) and 13 to 16 (cold) with switch in high charge position. Should I be concerned? If this is not good, how can I reduce charge rate further?
Also, are replacements available for the filter screen in the gas strainer bowl?
Post a Followup
: Re: H Strainer Bowl and Charging Rate
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
