Re: Serial #
Posted by D Slater on March 22, 2009 at 06:03:34 from (71.164.35.138):
In Reply to: Serial # posted by JH460 on March 22, 2009 at 05:46:30:
If it has the original engine the engine serial # stamped in engine block. Located in the area below the first spark plug will be the same as tractor.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
