'50 M Transmission main shaftand seal removal Adv
Posted by Sagebrusher on June 12, 2007 at 20:04:34 from (69.19.14.15):
Hello, This time it is bad seals and loose bearings on the old girl"s transmission main (input) shaft and Lift-all drive shaft where they emerge from the front of the transmission. The lift all drive shaft I think I have a handle on. The transmission side drive coupling even unscrewed in a decent manner and came right off. I ran a search back to 2001 but could not find definitive advice on removing the main shaft drive coupling. We disconnected the joint between the clutch shaft(?) and the transmision input shaft, loosened the drive shaft coupling and pulled it forward untill it hit the clutch shaft coupling. The half moon key came out but no luck on getting the coupling off the shaft. No amount of back and forth juggling would give us enough clearance to remove the coupling. We pulled the "Transmission Driving Shaft bearing cage" (bearing and seal flange assembly to me) but even that would not allow removal of the stub shaft and the coupling as a unit. Does the tractor have to be split to remove the driving shaft coupling on the transmission side? Will removing the clutch linkage allow enough clearance to pull the coupling off? Thank you in advance. I have learned a lot from following your seasoned advice and experience. Best Regards Don
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
