Re: Super H distributor drive gear
Posted by Owen Aaland on June 04, 2007 at 21:55:23 from (198.70.47.162):
In Reply to: Super H distributor drive gear posted by dtk on June 04, 2007 at 19:39:32:
As long as you are not going to use a magneto you can ignore the timing marks. Just get the distributor gear timed correctly to the adaptor gear. Turn the engine until you are cominmg up on #1 compression. Continue to turn until the TDC mark lines up. Install the distributor drive assembly. Remove the distributor from the adaptor. Find #1 marked on cap. Point rotor toward where #1 wire plugs in the cap. Install the distributor with the primary connector facing away from engine block. Remove rotor and dust cover. Rotate distributor Clockwise until primary connector is down about 45 degress. Watching the points, rotate the distributor back counterclockwise until the points just start to open. That should get you close enouigh to get it running so it can be timed with a light.
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
