Farmall Tractors Discussion Board
Re: H Starter and Alternator
Posted by TomH on May 09, 1999 at 11:49:32:
In Reply to: H Starter and Alternator posted by TomH on May 09, 1999 at 06:06:07:
I found the problem. I knew the battery was good (actually I had jumper cords from my pickup to the tractor and it wouldn't crank even with the truck's engine running). Preparing to remove the starter I cleaned out a large accumulation of crud, built up from dripped hydraulic oil, battery leakage, chaff, etc. After cleaning it off I hit the starter switch one last time; as you can guess it spun quickly and fired right up. I don't understand how junk underneath the starter was draining off current but it must've been grounding something. So next I put the 6 volt battery and old coil back on (with no alternator or generator) and of course it started again. So now maybe I don't need the big alternator (although I still have a generator/regulator problem, which is why I started to convert to 12 volt in the first place). But then a three pound coffee can and a little JB Weld might give the hood a custom look...
Post a Followup
: Re: Re: H Starter and Alternator
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
