Farmall Tractors Discussion Board
Re: H Starter and Alternator
Posted by RKS on May 09, 1999 at 09:13:32:
In Reply to: H Starter and Alternator posted by TomH on May 09, 1999 at 06:06:07:
also, unless your alternator just happens to be a rare "pos ground system," you must make sure your H is converted to "neg ground." The alternator won't work if not. Also, you have to know if it is an internally regulated model or requires a voltage regulator. You must be positive, or you will fry the battery (maybe a new one, huh?). If it has a clip with "F" for field marked on it, you will probably need a voltage regulator (recommend AutoZone 129965 VR706). There are other issues which you must be aware of in the wiring of the system. Good luck. RKS
Post a Followup
: Re: Re: H Starter and Alternator
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
