Re: Spark found
Posted by El Toro on May 19, 2007 at 03:54:21 from (64.12.117.8):
In Reply to: Re: Spark found posted by CNKS on May 18, 2007 at 19:08:23:
When your No1 piston is at TDC on the compression stroke, your timing mark on your damper pulley should be aligned with the pointer. Then remove the distributor cap and see where the rotor is pointing. If you are hand cranking the engine once you feel that compression you can drop a large handle screwdriver on top of the piston. Make sure the handle is large enough so you don't lose the screwdriver. Then you watch the screwdriver as it rises as you slowly crank the engine. When that screwdriver quits rising your piston should be at TDC. That rotor should at the No1 plug tower. If it isn't gently pull the distributor and rotate the rotor to the No1 plug tower and reinstall the distributor. Both valves will closed on No1 piston when at TDC too. Hal
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
