Re: SA hard to start
Posted by Gene-AL on May 06, 2007 at 15:49:20 from (65.4.35.138):
In Reply to: Re: SA hard to start posted by GordoSD on May 06, 2007 at 09:54:41:
Switch Off. Take the distributor cap off, turn the engine over in its normal direction with the starter (or fan blade) and note which way the distributor rotor turns. Then rotate the distributor in the same direction that the rotor turned to retard timing. Time engine (paraphrasing IH): 1. Determine which way the rotor normally turns (above). 2. Switch Off. Loosen distributor clamp bolts. Remove #1 sparkplug (nearest radiator). Place thumb over SP hole & turn engine until pressure is felt. Use a flashlight to see top of piston & turn engine slightly (w/fan blade) for piston at highest point of movement (or DC on timing mark). 3. Remove center wire on dist cap & wedge it under a dist cap clip so it's end is positioned 1/16 to 1/8" from the dist points/coil terminal. 3. Turn on Ign switch and check Ammeter for Discharge indication. If no Disc, turn dist in same direction as rotor normally turns just until Ammeter does show a discharge. From a Discharge showing, advance timing by slowly turning Dist back in the opposite direction to normal rotor rotation and stop when a spark occurs at the wire you wedged in the clip. 4. Turn off switch, replace wire, sparkplug, and tighten distributor clamp.
Home
| Forums
Today's Featured Article -
History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
