Re: How much can an H lift?
Posted by john d on April 08, 2007 at 15:00:52 from (69.130.182.233):
In Reply to: How much can an H lift? posted by lekander883 on April 07, 2007 at 18:52:48:
It depends on the following variables: 1) Condition of the belly pump. If it's a late H, or has the improved setup, it can develop about 700 psi. If someone has shimmed the relief valve spring, it might even hit 900 to 1000 psi. 2) Diameter of the cylinders. A 3" diameter cylinder has a surface area of about 7 square inches. A 4" diameter ram has a surface area of about 12.5 square inches. Multiply the surface area times the psi from the pump, and you have the theoretical force the cylinder can develop. If you have two cylinders, then you can push with twice that force. 3) The geometry of your loader. If the tops of the cylinders are located closer to the bucket of the loader, it should lift more than if the cylinders are attached farther back on the arms. The angel of the cylinder to the loader arm can also affect this. In theory, if the cylinder is about 90 degrees to the loader arm and mounted close to the center of the distance from the lift point to the rear arm attachment, then the loader could lift about 1/2 of the total force developed by the two cylinders. If the hydraulic system is in really good shape, and you have loader cylinders in the 2.5" to 3" range, you can lift enough weight to literally ruin your tractor. The rear end will also become very light.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
