Re: REMOVING GREASE AND GASKETS
Posted by GeneMO on March 13, 2007 at 09:26:41 from (72.47.42.87):
In Reply to: Re: REMOVING GREASE AND GASKETS posted by JayWalt on March 12, 2007 at 18:16:04:
I keep NAPA gasket material on hand. I generally keep several thicknesses and also keep a sheet of cork on hand. If You can cut the old gasket off it can be used for a pattern. Or you can lay the part down over the material and trace around it and also mark where the holes are. Sharp sissors around the outer edge, you can use an exacto knife, whatever works. Depending on the part you can also lay the material over it and using a ball peen hammer real carefully tap around areas and the hammer against the sharp edge of the piece will cut the gasket material. I handload pistol and rifle cartridges so I have a lot of empty cases around. I chamfer the inside of an empty case and use it for a cutter for holes. just place it over where you have the holes marked,put some soft wood underneath, and whack it good with a hammer. 30-30's are .308" diameter, 270 winchester is .277, etc. Finally if gasket sealer is needed, I like the stuff Caterpiller sells. I prefer to buy gaskets if possible, I just use the above method for hard to get stuff or when I dont have the time to go to town. Gene
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
