Farmall Tractors Discussion Board
Re: Re: Timing marks on H
Posted by justin on April 18, 1999 at 14:13:51:
In Reply to: Re: Timing marks on H posted by The Red on April 18, 1999 at 13:18:44:
One thing to consider, is that the tractor may have IH firecrater pistons in it.. If so, the timing has to be advanced 15 Degrees so that the tractor runs with efficient and with more power.. The only way to check is to take the head off.. The thing that may not make sense, is that IH made a distributor advance changeover kit, which just meant that you had to change a few parts to make the timing correct for the timing marks on the tractor.. NOTE: They also included a diagram that could be cut out to make an adjustment on the position of a mag or distributor if the changeover was not available, so that may explain the setting of your distributor or mag.. Hope this helps..
Post a Followup
: Re: Re: Re: Timing marks on H
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
