Farmall Tractors Discussion Board
Update On Cracked, Stuck sleeve
Posted by TMAC on April 03, 1999 at 18:39:05:
I first heated the sleeve for 15 minutes with a propane torch and then started to pull it as it cooled down with ice and rock salt. No go. I discovered also there is a crack at the top of the block so it may not keep water out of the oil. So now I plan to search for another F30 block and sleeve. The old block will be sledge-hammered to remove the remaining sleeves out. Thanks again for your suggestions.
Post a Followup
: Re: Update On Cracked, Stuck sleeve
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
