Farmall Tractors Discussion Board
Re: C =H or M
Posted by Phil Auten on April 03, 1999 at 11:07:25:
In Reply to: C =H or M posted by Richard J on April 01, 1999 at 17:15:21:
Richard,
I have both a C and an M. The M is by far the winner when power is needed. 247.7 CID in the M vs. 116 CID in the C. You just can't beat cubic inches! BUT, that's not the only consideration when making this purchase. The C is a very nicely sized utility tractor, it just doesen't have a lot of power. The 15 or so HP it does have will do most of the jobs you have outlined, you'll just have to do them SLOWER than you would with an H or M. The H is a better choice than the C as far as versatility goes, but the H and M don't have the advantage of the smaller size of the C for some jobs. If your place is open, with few obstructions to make maneuverability a requirement, go with the M. You can never have too much power. If money is not a problem, get them all! You can never have too many tractors!
Basically, the best advice was to see if you can try out each of them and then pick the one that suits your needs best, if you can only afford one, that is.
Good luck,
Phil
Post a Followup
: Re: Re: C =H or M
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
