Re: H problems
Posted by Haas on December 30, 2001 at 11:06:06 from (129.37.117.236):
In Reply to: H problems posted by Dave Z on December 30, 2001 at 08:38:08:
Sounds like your carb float may be set too high, or it is sticking, or it has a hole in it. As to timing the mag, the manual will tell you to do it with the engine stopped. Take the center wire out of the distributor, then Take the mag bolts loose and rotate the mag back as close to the engine as you can. Then turn the engine until it is TDC of the compression stroke on No. 1 cylinder. Then rotate the Mag out from the engine until you hear the impluse coupling trip. Then tighten the mag up and check by rotating the engine until you hear the impluse coupling trip. It should then be at TDC. It it is at TDC, it is timed correctly. I'm giving you what the manual says. I thing the engine will run about anywhere within the adjustment of the mag timing. If your impluse coupling is not triping uniformly, or is sticking, you will not get it timed correctly. If the impluse is not operating correctly, it will be hard to start. If your H is 12 volts is converted to 12 volts, it should start on the 1st or 2nd turn.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
