Re: Thinkin about tradin it. Any tips?
Posted by Haas on November 14, 2001 at 06:00:25 from (129.37.117.100):
In Reply to: Thinkin about tradin it. Any tips? posted by Kenny Christopherson on November 13, 2001 at 20:07:46:
Regards your charging problem. Are you sure the voltage regulator has a good ground?? First run wire from the generator field connection to the battery ground. If the generator starts charging, it is OK and you problem is the regulator. Take the wire off and then run the wire from the battery ground to the mounting lug of the regulator that has the ground copper ground wire connected to it. If the generator is charging with that wire connected, then find a good ground on the tractor and permanently connect the wire to ground the voltage regulator. I had a tractor that would not charge until I added that wire to ground the regulator. If the regulator is mounted to a painted surface, it is enough resistance to keep it from charging. The regulator must have near zero ohms to ground for things to work. Even 3 or 4 ohms measured with a meter is too much.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
