Re: IH 2444 Brake Problem
Posted by IH-NEAL on November 07, 2001 at 06:48:12 from (216.165.154.40):
In Reply to: IH 2444 Brake Problem posted by Dick Reivitt on November 06, 2001 at 19:18:15:
Dick: YOU CAN HAVE ACCEPTABLE BRAKES ON THAT TRACTOR. PROBABLY NOT EYE POPPING BUT ACCEPTABLE. FIRST THING TO DO IS CHECK AND SEE IF THE DISCS ARE GLAZED, NOT TO UNCOMMON, IF THEY HAVEN'T WORKED GOOD FOR SOME TIME. MY ADVICE WOULD BE TO GET NEW ONES, NOT NECESSARILY FROM IH, GENERIC WILL DO. NOW CLEAN UP THE HOUSING, WEAR A MASK WHEN DOING THIS, DON'T INHALE THE DUST. CLEAN UP THE ACTUATORS. TAKE THEM APART AND CHECK THE STEEL BALLS, CLEANING OR REPLACING AS NECESSARY. WHEN INSTALLING DISCS, PUT SHARP EDGE OF INNER BORE OF DISC AWAY FROM ACTUATOR. ON ACTUATOR TOGGLE BE SURE TO CLEAN UP PIVOT PIN AND LUBE WITH NEVER-SEIZE, MAKE SURE AND CLEAN ANY PIVOTS FROM BRAKE PEDAL TO BRAKE PULL ROD AND LUBE WITH NEVER-SEIZE AS IT WILL KEEP IT FROM RUSTING AND CAUSING FRICTION. YOU SHOULD HAVE BRAKES THAT WILL AT LEAST SLIDE THE WHEELS. ANOTHER TRICK IS TO KEEP BRAKES APPLIED AND LOCKED WHEN EVER IT IS STATIONARY. GOOD LUCK DICK. NEAL S.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
