Farmall Tractors Discussion Board
Re: Is this a Super A two Bottom plow?
Posted by JohnHealey on March 06, 1999 at 18:00:11:
In Reply to: Is this a Super A two Bottom plow? posted by Daniel on March 06, 1999 at 17:41:02:
Daniel, The Super A is rated for a single 16-inch plow. You are right in that the drawbar is turned around and the plow hooks to it . The Super A plow would have two springs in the bracket that attaches ( by two bolts ) to the drewbar. The springs absorb shock when the plow hits a rock, etc. Where the drawbar brackets attach to the final drives there is a pin and a bolt through the drawbar, the bolt is removed so that the drawbar can pivot on the pin . A bar is then attached from the drawbar up to the rockshaft on the right side of the touch control unit. The furrow depth is controlled by raising or lowering the drawbar and thus the plow beam. The rockshaft on the left side of the touch control unit is used to raise and lower the plow itself. When you say you have a two bottom, are you sure you don't have a right and left hand plow? John
Post a Followup
: Re: Re: Is this a Super A two Bottom plow?
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
