Re: Re: ANOTHER 140 QUESTION
Posted by HavinFuninMo on September 04, 2001 at 15:59:48 from (64.196.152.4):
In Reply to: Re: ANOTHER 140 QUESTION posted by Jman on September 04, 2001 at 15:04:19:
Hey,
I added a worksaver 3 point kit to my 140 earlier this year. For this kit to "bolt right on", you need the arm that runs from the rockshaft to a pivoting shaft mounted between the rear fenders and that pivoting shaft assembly. (Not sure of the name for it) If that is intact, it is a bolt on. If you still had a drawbar, it would have to be removed. I am pretty happy with my 3 point.
On an AV my father had, we added a PTO. Took the PTO shaft/rear housing cover from a donor A and added to the AV. Had to find a different shaft that ran between the PTO assembly and rearend as the coupler from donor to AV was different. Since the 140 is a decendent of the A it might be similar. not sure though. Someone else might be able to give more details.
Post A Followup
: Re: Re: Re: ANOTHER 140 QUESTION
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
