Super M engine cleaning
Posted by Pawnee on August 27, 2001 at 09:46:19 from (207.51.255.129):
MY M runs but needs some adjustments. I am sort of doing this backwards because i have already cleaned it and painted it. I plan to go through the cooling systems to clean, flush out and replace gaskets and thermostat. I am planning on using the method suggested here(1/4 cup of dawn). I also want do as much as i can to clean scale and rust and then protect the engine passages. What is the best way to do this with the least tear down. I also plan to do the same with the lubrication system. Remove Pan and clean the oil pump. Remove the valve cover and clean sludge and hopefully adjust valves. Then i will do the same for the tranny and hydrolics. Probably add diesel and run a while to flush and clean. Drain and and new oil. Main question concerns cleaning oil and water passages. Can and should i blow out with air or pressure washer with or without soap. I have printed a lot of tips off here but if you have some that i haven't mentioned i would appreciate hearing them. After the cleanings i will clean and replace ignition parts as needed. I will also remove plate on governor and i have already put a Carb kit in. What else along these lines? Any warnings! Ya'll are great! Thanks for any help in advance
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
