Re: Re: Re: Cause of little or no oil pressure in MD
Posted by Haas on July 18, 2001 at 13:08:42 from (129.37.117.227):
In Reply to: Re: Re: Cause of little or no oil pressure in MD posted by Ross on July 18, 2001 at 08:02:06:
Not sure how you would tell for sure, but if the diesel is getting into the oil, I think the leaking seal would be at the front of the injection pump where the shaft that drives it off the front timing gear goes into the pump. Don't think there is any other way for diesel to get in the oil. The injection pump has it's own little sump that holds about a pint of oil. Diesel can leak into that too. That leak is usually from the fuel pump located on the back end of the injection pump. The diesel may leak from that seal into the injection pump and then into the oil. If it's doing that, the level in the injection pump sump will be high. You check that level with the little petcock on the side of the injection pump. It should be full up to the petcock with same oil that is in the engine. If you change the engine oil and you get better oil pressure, that is bound to be your problem. Also make sure the diesel return line from the pump back to the tank is open and working.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
