Re: Oil pressure M diesel
Posted by Medfarm on July 07, 2001 at 10:53:48 from (209.162.21.96):
In Reply to: Oil pressure M diesel posted by Paul on July 07, 2001 at 06:59:51:
Paul One major assumption is that the valve train is working properly. By removing the valve cover and spinning the engine slowly, you can see obvious problems. On any old tractor that had set for long time, all filters and fluids should be changed. Since the M is a diesel, the engine had to run on gas before switching to diesel. I would recomend that you remove spark plugs, have start lever on gas (so third valve will be open) and crank the engine. You can remove the valve cover and watch for oil in the rocker arms. As far as the diesel system is concerned, bleed all air after changing the filter and bleed injector lines. The old diesel will not corrode or decay the fuel injector pump. We have started old IH diesels that have set for 5 years and the diesel system is not a problem. Water condensation in the system is and the gas system is a major headache. Before trying to start the tractor, check ignition system and plugs. The gas tank, fuel line and carb will probably have to be cleaned. The butterfly shutoff in the intake manifold needs to completely block the air intake for the carb to work properly. If it does not, the engine will never start. Lat week, we started and operated a IH TD-18A crawler that had set for 5 years. It took alot of fiddling and cleaning but the old girl finally bellowed to life. Such a beautiful sound when switching from gas to diesel. Good luck Ray
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
