Re: super c timing help
Posted by Kurt T on July 03, 2001 at 19:24:33 from (204.233.241.113):
In Reply to: super c timing help posted by dan on June 30, 2001 at 10:48:09:
This is how I did it a couple weeks ago. First, pull the spark plug from the #1 cylinder (front). Second, turn engine over using fan blade to get piston at top dead center. Turn fan blade in correct direction. As you or someone turns the engine you should feel some compression building in the cylinder. If you do you are on the compression stroke. If you don't feel compression you will have to turn the engine over again until you do feel compression. When you start to feel compression, stick a long screwdriver into the spark plug hole. The top of the screwdriver will touch the piston. Slowly rotate the engine until it's clear you have top dead center. Now you want the rotor to point exactly at the dist cap #1. To get it to point very close, you will have to remove a small cover under the rotor and index the shaft a couple gear teeth to get the rotor to point correctly. This will take a couple tries. The engine will fire right up when you are done. If the engine runs hotter than normal, advance the timing slightly. Good Luck
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
