Re: Need all the help I can get on replacing rear housing on H.
Posted by Jeff on June 28, 2001 at 09:44:30 from (63.150.94.35):
In Reply to: Need all the help I can get on replacing rear housing on H. posted by Nick on June 28, 2001 at 09:27:11:
A year ago I got an H with the transmission removed. It was fairly easy to put back in. The rear of the sliding gear shaft has 3 or 4 bolts you remove, and the front is a roller bearing that just slides out of the middle of a gear that connects to the constant mesh gear. This gear, and the belt pulley gear, are held in place by 5 or 6 9/16" bolts located in the chassis where the hydraulic pump unit goes. You can remove it without removing the pump, but IT'S A PAIN! You're better off removing the pump (which is very heavy). The rear of the counter shaft sets in a ball bearing and stays there with a snap ring. The front of the counter shaft screws into a coupling for the hydraulic pump shaft; there is also an oil seal. One trick is when you mate the front of the sliding gear shaft bearing with the constant mesh gear: make sure you put them together carefully, because the roller bearing retainers will unseat the rollers if they have much force put on them (I did this last fall). The best reference I had was the parts catalog and the engine service manual; I studied them a lot before I did anything. I also have pictures of the gears in place as well as other transmission housing pictures (1940 H).
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
