Re-reading your original post, I'd concur with the above posts:
Note the piston locations if they aren't already marked, remove the rings and clean them and the grooves on each one.
Keep the shim stack locations as previously noted, but Plasti-gage is cheap (a $2.00 strip should do all 4 with a couple trys each) so you can set them easy enough.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
