Re: IH 300 Carb Problems
Posted by dick on May 25, 2001 at 07:40:19 from (63.120.111.98):
In Reply to: IH 300 Carb Problems posted by Doug Kervin on May 24, 2001 at 17:58:28:
Doug: On your gas leakage problem, chances are that the level in the bowl is set too high. This is particularly true if the leakage you are seeing is present when the engine isn't running. Solution is to bend the float support a bit so that the valve it controls shuts off when the gas level in the bowl is at a lower level. On the RPM problem, I'm assuming you've already tried backing the idle screw out to where it's not doing anything. My guess is that the linkage coming over from the governor to the throttle plate in the top of the carb. is where your problem is. When you install the carb., you have to be careful to get this linkage lined up correctly with where it joins the throttle plate, and it sounds as if this might not have been done with yours. While the carb. is off you can check the throttle for full travel and should be able to localize your problem - which could be in the governor as well. From the problems you're describing, I doubt that a rebuild is really necessary, but you should plan on pulling the carb. and seeing what's going on in there. A really good thing to do would be to invest in a couple of gaskets for where it joins to the manifold and where it separates; lots of problems caused by leakage at these points. The carburetors on these tractors are straightforward enough that most people are successful working on them, so I wouldn't be afraid to try this if you've never worked on one before. Good luck.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
