I have been asking all kinds of questions about Farmall C/Farmall Super C Plows. Some very helpful tips. I can't say wether or not I can help but will try.
It sounds like a C-294 Plow. They are controled with the touch control, where one lowers the plow and the other sets the draft. I believe that is what they called it? The one that sets the draft I believe is causing the problem. Is there a way of making an adjustment like a turn buckel? Sounds like you have to take up on that slop, and not seeing it makes it difficult. Hope this helps.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
