Re: Hot running Super A
Posted by Red Dave on March 02, 2001 at 06:09:02 from (208.165.46.34):
In Reply to: Hot running Super A posted by Jeff on March 01, 2001 at 17:58:53:
That tube that runs from under the cap down the side of the radiator is often damaged or missing alltogether. If yours needs repair or replacement, a lot of folks just use a piece of rubber gas or vaccuum hose and route it down the left side of the radiator to the area of the drain plug. That keeps the overflow from blowing all over the motor when it hits the fan. The other posts are right about the coolant level, just don't let it get too low or the thermosyphon system won't work. A little overflow when the tractor is hot and working hard is normal.
Post A Followup
: Re: Re: Hot running Super A
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
