Tractor Talk Discussion Forum
The first p.t.o.
JD 41 B
04-20-2008 16:31:16
I was wondering if anyone knows the first tractor to be equipped with a power take off and what was the first implement made to run on the tractor's power take off. Just curious.
Burnie
04-20-2008 23:30:42
 Re: The first p.t.o. in reply to JD 41 B, 04-20-2008 16:31:16
I've just been reading an article on the history of PTO, in the 'Australian Grain' magazine. The information pretty much goes along with what others have said. The article by Dr. Graeme Quick, says: "Arguably, the first tractor PTO was on the French Gougis tractor in 1907. In 1919, the International Harvester Company began experimenting with PTO-equipped International 8-16s, and in 1921, the PTO became available on special order for Model 15-30.
The 1924 Farmall 'Regular' had the PTO as an integral part of the tractor's design."
The article also says that early PTO on mobil equipment was a chain driven Aveling and Porter Bell reaper of 1878. Around the same time, in California, George Stockton Berry built a combine, powered by steam drawn from the traction engine via flexable hoses.
Athol Carr
04-20-2008 19:45:40
I believe IH 8-16, for which a special tractor binder was developed about 1918. I believe that the idea came from an experiment in France with a tractor driving a binder. The McCormick Deering 10-20 and 15-30 were available with a PTO attachment from start of production and the first Farmalls and right through the F-20, F30 and F-12 had a pto as standard fitting.
Sid
04-20-2008 18:52:10
My guess would be the threshing machine was one of the first if not the first machine to run off a belt pulley. Which in my opinion would be a early form of a PTO.
John M
04-20-2008 18:45:14
IH 8-16 with a binder, maybe? Seems like I read that somewhere.
Lanse
04-20-2008 17:51:46
if i had so guess, i'd say a mower. I'd also say i think it was a McCormick-Deering 10-20 or a 15-30 or something
Phil Wilkerson
04-20-2008 17:41:41
I have a 1930 John Deere GP Wide Tread and it has a PTO shaft facing the front and the rear. I'm sure its not the first for a PTO shaft but it may be the only model with a shaft facing fore and aft.
Coltond202
04-25-2008 13:53:25
 Re: The first p.t.o. in reply to Phil Wilkerson, 04-20-2008 17:41:41
Our 1930 Gp Standard also has this setup. I know that for the Gp it was an option, and also it could later be added on.
thurlow
04-20-2008 18:40:22
Have had a bunch of John Deeres.....none older than 1963 year models..... ...that have both front and rear facing shafts.
