Tractor Talk Discussion Forum
noisy hydraulic pump
DAVE`
03-07-2008 13:47:29
I just recently purchased an 860 ford.I found that after it ran for 10 to 12 I began to hear a rather loud noise at the rear of the hyd pump.I have checked cam shaft end play and changed the drive end of the pump assembly.I have also made sure I have some backlash between gears. I have also removed the stack valve and put the plate on to eliminate the remotes as any part of the problem. The pump works fine and the noise will stop when the loader is raised or lowered but using the 3 point lift arms does not change the noise. I am stuck and would sure appreciate any help. Dave in the Hoosier State,
circus
03-08-2008 06:20:32
 Re: noisy hydraulic pump in reply to DAVE`, 03-07-2008 13:47:29
Usually valving has bypasses. Perhaps yours doesn't and your hearing a relief valve buzz.
