Tractor Talk Discussion Forum
engine stuck on poppin Johnny
Bob Begey
02-22-2008 02:29:50
This subject has probably come up a million times. Anyone got any cures for a stuck engine on a 47 John Deere? Tractor sat outside for a couple of years without startup and I would guess that condensation is the culprit. I had the inlet stack covered to prevent rain from entering the intake. Have removed the cylinder head and do see some minor rust build up on the cylinder walls which I have cleaned up. Of course I can't get to the area which is the ring seating which is probably the area it is stuck.
36 coupe
02-22-2008 16:22:54
 Re: engine stuck on poppin Johnny in reply to Bob Begey, 02-22-2008 02:29:50
Jack up a rear wheel and rock it back and forth.Take the time to turn the engine over on idle tractors.
deeredv1
02-22-2008 10:38:58
If you do end up pulling the block with the pistons and rods, stand the block up vertically on some blocks.Boil a large pan of water and dump the water into the water jacket of the block.The hot water will expand the block in a hurry and light tapping on the pistons with a block of wood and a hammer will get them loose.Ive had great success with this.Good luck
old
02-22-2008 09:04:13
Jack the front of the tractor up say 2 foot or so. Then fill the cylinders with tranny fluid, it does work better then PB does by a long shoot. The reason for jacking the font up is because of the way the cylinders lay on a JD. BTDT on my 1935 JD-B and I knew it had been locked up for 15 plus years and it now runs just fine and I never pulled the head off of it. I have run tests using PB and ATF and the ATF has always worked better on things I have used it on
Den N Ms
02-26-2008 14:15:13
 Re: engine stuck on poppin Johnny in reply to old, 02-22-2008 09:04:13
I have run tests also and PB Blaster works way better than ATF.
old
02-26-2008 14:25:34
 Re: engine stuck on poppin Johnny in reply to Den N Ms, 02-26-2008 14:15:13
Well all the times I use PB it hasn't worked for me, but the ATF has. Plus at $2 a qt. for ATF and $10 or so per QT. of PB the ATF is the way to go since to pop an engine free you have to almost fill the cylinders. turpentine and ATF mixed 50/50 also works well but again the turpentine is hard to find and at $10 plus a QT. I'll again just stay with the ATF
Clyde Parrish
02-22-2008 04:41:44
If you already have the head off why not take the rods loose and pull rods and cylinder block. Then stand it on end and dump a little brake fluid and diesel mix on top of the pistons and light it. Then when its good and warm they will tap right out with a block of wood. I remember clooney saying that over on the deere board a long time ago.
hillbillyOH
02-22-2008 04:02:50
Paging Lanse... Lanse to the white courtesy phone please...
Lanse
02-22-2008 04:53:10
 Re: engine stuck on poppin Johnny in reply to hillbillyOH, 02-22-2008 04:02:50
pour some PB blaster on there. If youre in a hurry, use PB if not ATF. ATF takes longer but i am confident it'll work.
El Toro
02-22-2008 03:45:03
Pour some ATF on top of the pistons and let it soak. Hal
gene bender
02-22-2008 06:11:30
 Re: engine stuck on poppin Johnny in reply to El Toro, 02-22-2008 03:45:03
Hey kiddo its hard to pour oil on top of a JOHN DEERE piston when its in the tractor ya been around them good RED ones too long
El Toro
02-22-2008 07:08:54
 Re: engine stuck on poppin Johnny in reply to gene bender, 02-22-2008 06:11:30
I forgot about those horizontal pistons. We only had red ones. Hal
omahagreg
02-22-2008 05:48:47
Some of you guys seem to forget, this is a horizontal engine. As it sets in the tractor, there is no 'top' of the cylinder. Complicates things just a bit! Greg
Dick L
02-22-2008 06:36:19
 Re: engine stuck on poppin Johnny in reply to omahagreg, 02-22-2008 05:48:47
Easy to do if you set your mind to it. (:^D
third party image
Lanse
02-22-2008 11:09:09
 Re: engine stuck on poppin Johnny in reply to Dick L, 02-22-2008 06:36:19
now theres a way to get mine running, threaton to dangle it from a crane :-)
