Tractor Talk Discussion Forum
Dresser 530c loader help needed
Brian Bell
01-02-2008 18:38:09
Anyone out there got any experience with a Dresser 530c loader? I'm stuck on one and could use some help! It won't move...all other hydraulics work except transmission. Need help with troubleshooting...cannot find a repair manual.
Brian Bell
01-03-2008 06:23:58
 Re: Dresser 530c loader help needed in reply to Brian Bell, 01-02-2008 18:38:09
No. It was bought like this and has sat for a few years. Have good pressure coming from the pump (2200-2300 psi). I have found a few valves that were rusty that I have honed/cleaned up to get functional again but it"s almost like there is no pressure getting to the clutches in the trans allowing it to shift into gear. I am tracing the hyudraulics as best as I can without a manual but that"s a daunting task. Do you know the path the hydraulic fluid takes from the pump all they way thru the trans? I have pressure getting down to the trans but apparently not inside to do the shifting.
El Toro
01-03-2008 08:27:43
 Re: Dresser 530c loader help needed in reply to Brian Bell, 01-03-2008 06:23:58
Since Dresser sold this to Furival and was sold again you may want to contact this man by email
that's still with Dresser. Here's a web site to contact the company that has the business now. You will need to change the last 2 letters for your state to find someone in your area. Hal
j.nehl@dresstanorthamerica.com
www.equipmentcentral.com/locator/customer/display.cfm?region=North_America&territory=md
Note: Change the last 2 leters from md to your state.
Trkr
01-02-2008 19:52:25
What happens when you shift it into gear?It should have a little elecric switch on the side of the dash that releases the parking brake.Did this happen all of a sudden?
