Tractor Talk Discussion Forum
JD 1120 steering has a lot of play
Paul Tremblay
10-21-2007 14:59:48
Does anyone have information on how to adjust the steering on a JD 1120
I have a lot of play in the steering wheel.
Tx Jim
10-22-2007 03:46:58
 Re: JD 1120 steering has a lot of play in reply to RN, 10-21-2007 14:59:48
Have you checked all the tie-rod ends. The ones on the end of the long piece from center to frt. axle also. The bellcrank in center of frt axle has bushings or bearings than can wear out depedending on SN. If valve body itself is loose inside then to repair it has to come apart. Tx Jim
