Tractor Talk Discussion Forum
Wagon Running Gear Size
Jeff C. in Mari
04-11-2007 13:19:34
How can I tell what ton gear I have on my old haywagon? Does spindle size have anything to do with it? I don't want to overload this old wagon, but I want to put it to good use.
JWC in MS
04-11-2007 15:46:40
 Re: Wagon Running Gear Size in reply to Jeff C. in Marion, Oh, 04-11-2007 13:19:34
5 lug with 15” rims or narrow 16” rims will run from 3 to 5 tons, 6 lug will be 5 to 7 ton unless they have very heavy rims and 10 ply or heavier tires, 8 lug has a wider range. Any wagon will not have a heavier weight rating than the total weight rating of the rims or tires whichever is least. There are many old hay, corn, cotton and other running gears still in use over 50 years old. The wear in the steering linkage on an automotive type steering wagon will greatly impact how fast it can be safely pulled. The wear on the kingpin of a 5th wheel steering wagon can be a hidden problem. A good rule would be to start with your tire capacity (assuming they are in good condition and are the right size and type for the rims) and cut back according to the wear in the steering, hitch points etc. Wagons do not transfer any weight to the towing vehicle and very few have brakes so don’t load more than you can stop or steer. If you post here and mention the # of lugs, the rim size, tire size and the brand you can be given a better estimate. Don’t forget to take include the weight of the gear, bed and tires is included in the load capacity.
jhill52
04-11-2007 13:40:32
The number of lugs on the wheels is a good indication of load capacity. 5 lug are generally 4 ton 6 are 8 - 10, 8 lugs are 12 ton.
