Tractor Talk Discussion Forum
Perkins 6.354 engine
Rainer
02-23-2007 11:27:34
I am rebuilding my Perkins 6.354 engine of my combine and now I want to test the injectors. Can someone tell me what the pressure must be?
Thanks Rainer.
barnrat
02-23-2007 12:33:59
 Re: Perkins 6.354 engine in reply to Rainer, 02-23-2007 11:27:34
What combine is it out of? All I can tell you is at least 2500psi.
Rainer
02-23-2007 12:45:25
 Re: Perkins 6.354 engine in reply to barnrat, 02-23-2007 12:33:59
Thanks Barnrat.
It's a Bautz combine, made in Germany. The company was bought by Claas in the early '70's
barnrat
02-23-2007 14:38:12
 Re: Perkins 6.354 engine in reply to Rainer, 02-23-2007 12:45:25
The non turboed Perkins 354's of that era had a nozzle pressure of 2500 psi. Hope that helps.
Rainer
02-23-2007 22:21:20
 Re: Perkins 6.354 engine in reply to barnrat, 02-23-2007 14:38:12
Yes it's a nonturbo engine. I have tested 1 injector at 2000 psi. Do you know how I can increase the pressure? Or is that work for a professinal.
Kevin (FL)
02-24-2007 09:04:40
 Re: Perkins 6.354 engine in reply to Rainer, 02-23-2007 22:21:20
Rainer,
The pop-off pressure is easily increased by tightening the spring tension. Remove the "cap" on top of the injector to access the spring nut. Also--make sure the injectors are showing a good pattern for atomization of the fuel. I would also verify the pop-off pressure before I set them. This affects injector timing and will affect proper running of the engine. (Too low a pressure, earlier "firing", too high a pressure, late firing. I was thinking the pressure on those was 2600-2800. I'll check to see if I have it in the manual.
