Tractor Talk Discussion Forum
set up case S magneto
heenk
01-09-2007 17:09:04
Thanks to all that have tried to help me solve my previous problem of the 4 th cylinder not firing.After resetting the valves ,plugs,wires and whatever else there was to check I found out that it"s in the magneto. It does fire but not at the right time in two of the 4 plugs.On the small gear is a mark but not on the larger one that has the contact point on it.How do I need to set the magneto.
Glen in TX
01-09-2007 21:49:37
 Re: set up case S magneto in reply to heenk, 01-09-2007 17:09:04
Taking a guess here that you have the Case 4JMA or 41 mag and on those there is a dot on steel gear and cam that should align with two beveled teeth on the fibre gear on rotor. The beveled teeth should face towards the rotor disc if gear is on right. Originally the beveled teeth and dot were painted red but it comes off over time.
