Tractor Talk Discussion Forum
tractor tank gas bowl
latech61
06-24-2006 17:30:00
Ever since i cleaned the glass bowl on my 1955 farmall 100, the tractor seems to not get enough gas to run correctly.It ran fine before,any ideas any one. thanks in advance
huntingreen
06-24-2006 23:06:15
 Re: tractor tank gas bowl in reply to latech61, 06-24-2006 17:30:00
Every time I put the glass bowl on real tight it will not flow enough fuel. Loosen your bowl up a little and try that.
MN Bob
06-24-2006 17:38:28
Many of the ones I have worked on had a filter screen, did that get plugged? next would be to blow back from the carb input to the bowl. Then the same from the bowl into the tank. If the one into the tank works, you have got to clean it out or put in a filter. Hope its the easy one. Bob
