Tractor Talk Discussion Forum
Help setting up Hydraulis pressure
Frank - Illi
01-03-2006 17:39:57
Is there any way to set up the hydraulic pressure on a Case 830 diesel ? I put a loader ( Freeman 4000 ) on the tractor, using the tractors hydraulics. It will lift the 1500 lb round bales, but not the 2500 lb ones. The pressure relief valve start to chatter and won't pick up the bale.
Thanks Frank
Don 2004
01-03-2006 19:02:57
 Re: Help setting up Hydraulis pressure in reply to Frank - Illinois, 01-03-2006 17:39:57
Yes the pressure can be set up, but you might want to check to see what pressure you have now. 2500 pounds is a heavy bale for a 830. The relief valve can be shimmed.
msb
01-03-2006 18:07:35
Can't say but you could put on larger lift cylinders.Larger cylinders will slow the cycle time but increase the lift capacity of the loader.
msb
01-03-2006 18:07:44
