Tractor Talk Discussion Forum
Mike M
Obie
11-22-2005 08:23:24
Hi there was reading your post about eye glases one of the gals I work with just found that Ziena Web. site and she is gona order a pair of eye glasses. Did you have good luck with your glasses you ordered from them? I think these places like Lenscrafters is a big rip-off.. What style of glasses did you get from that Ziena outfit? They have a lot of glasses to choose from...
Thanks Obie
Mike M
11-22-2005 09:48:20
 Re: Mike M in reply to Obie, 11-22-2005 08:23:24
I think we are both spelling it wrong ? I suppose it is the same place ? I just got the cheapest no frills or options just to see if the place was even legit because if it wasn't I would only be out $20.00 I am pleased and will order again but I should get my eyes checked to see if they changed. I got the ones that don't have a frame on the bottom because they are lighter and you don't get that frame blocking your sight. The only down side is that you can't try them on I would of perfered ones that had bigger dia. lenses so I don't have a blurry spot. I did see some other companies offering the same kind of services a little more money and I think they had some pictures you can print off and cut out and try on for size and look. I also think these places will put lenses in your frames too if you send them in. I think I waited about 2 weeks ? or whatever they say it takes it took that long.
Obie
11-22-2005 10:04:04
 Re: Mike M in reply to Mike M, 11-22-2005 09:48:20
Thanks Mike will check it out cause it would be nice to have a second pair just in case I break my only pair would be nice to have a fall back..
Thanks
Obie
