Tractor Talk Discussion Forum
generator help
Ronnie269
10-22-2005 05:09:50
I have a subaru ( diesel) generator model number SDG2200S, I'm haveing to run it at twice the normal RPM'S to get 120 volts, sixty cycles , can anyone tell me what could cause this? Also would like to get a tech manual on this Gen>
Thanks for your help
rlp2690@aol.com
Technoid
10-26-2005 16:55:02
 Re: generator help in reply to Ronnie269, 10-22-2005 05:09:50
Ron, I got your email. I would be glad to help out as much as I can.
Technoid
10-23-2005 07:55:36
I work on generators at my job. Depending on the number of poles, a generator will produce 60 cycles at either 1800 or 3600 rpm. This is a factor that does not change. The freq will change with the rpm. It is not possible to loose proportional freq/rpm.You need to have an accurate tach or freq meter. Watch the rpms as the engine loads up. Make sure the governor is maintaining the correct rpm. From what you wrote, it sounds like the voltage regulator or a winding went bad. Most likely a winding since you need more speed. To check the windings, you need an instrument called a meg ohm meter. It a small hand held generator with a crank that puts voltage into the winding. It tests the insulation break down. It reads back from megohms to ohms of short. If you use one, be sure to disconnect the voltage regulator from the circuit.
Kevin (FL)
10-23-2005 05:11:34
Ronnie,
Something ain't right here. Is this a direct-driven generator? Belt-driven off a pulley?? Diesel engines are governed to run at a specific RPM. Most smaller genset engines are governed to either 1800 or 3600 RPM. Larger diesels are governed at 1200 or even slower depending on size/HP. You can't take an 1800 RPM engine and force it to turn 3600--even if you override the governor, I believe it will come apart before you got to 3600 RPM. The same for the 3600 RPM engine--doubling the RPM will create a shrapnel grenade....With that being said, are you certain about RPM? Maybe a faulty tachometer?? If you don't have a good frequency meter, you can also use a phonograph and play a record--you'll hear the pitch of the music is off when the frequency is not at 60 hertz.
farmboysteve
10-23-2005 02:52:31
use a tv set. vertical hold uses 60 cycle from house current for sync to keep the picture from rolling.
RayP(MI)
10-22-2005 14:03:35
How are you measuring the 60 cycles?
Ronnie269
10-22-2005 16:18:51
 Re: generator help in reply to RayP(MI), 10-22-2005 14:03:35
RayP, I have a volt- Hz meter
RayP(MI)
10-22-2005 18:36:12
 Re: generator help in reply to Ronnie269, 10-22-2005 16:18:51
Check it against your house 110v outlet. See if it's reading correctly, then try it on your generator under load like a milkroom heater, resistive load. Some of the cheaper handyman meters tend to "bounce" and read incorrectly. Got an old electrical clock with a sweep second hand? Plug it in and see if the second hand "really flies!" (Evidence of 120hz.) If these backup tests seem to indicate that the generator is putting out improper frequency, voltage, best get it to a shop capable of checking it out - there's probably something wrong!
RayP(MI)
10-22-2005 18:35:54
buickanddeere
10-22-2005 08:59:11
Double normal rpm would be 120 Hz.
Jim_bobb
10-22-2005 07:23:47
My guess is a bad regulator module. Double RPMs will ruin the diesel engine.
