Tractor Talk Discussion Forum
exterior HYD lines
Just Bill
10-02-2005 01:04:52
Help: I am trying to get some info about how to hook up some Hydalic lines so i can put on a front end loader I have a 1952 8N I hope some one can help me out
Thanks Speed-Bump
bcPA
10-02-2005 19:33:53
 Re: exterior HYD lines in reply to Just Bill, 10-02-2005 01:04:52
with load in bucket and tractor facing down hill driven into pile of material my 8n would not back away from the pile without dumping load in bucket. I then took the loader off and have not used it since. I bought a 3 point scoop that works in both directions and a 3 point manure loader that will lift the load up about 6 feet off the ground and dont miss the ft end loader at all. just my take on this matter.
Gene Davis (Ga.).
10-02-2005 17:34:55
You will need a power steering kit to be able to drive it with a load in the bucket now!
Bob
10-02-2005 09:30:03
You can get a low GPM source (a little over 1 GPM) by chaining down the 3-point, and then tapping into the hydraulic test port on the pump. Others have given the fitting size. You then tap a hole into the axle side-cover for the return.
Or, you can get a 12 GPM pump, and a drive kit to drive it off the engine's front crankshaft pulley.
This site (YT) sells the drives and the pump.
Mike (WA)
10-02-2005 09:21:27
8N is a nice little tractor for some chores, but powering a loader off the tractor hydraulics isn't one of them. Not only is it agonizingly slow, but the internal hydraulic pump only operates when the clutch is engaged- that is, when you step on the clutch, everything stops. So you'll have a loader that's both anemic and intermittent. And did I mention infuriating? Get a front pump- its not difficult, and you'll have a loader that actually works.
Duner Wi
10-02-2005 07:08:34
I read that the pressure port is 1/2" by 20 TPI so pay attention to what you screw in the port.
Missouri Boy
10-02-2005 13:09:13
 Re: exterior HYD lines in reply to Duner Wi, 10-02-2005 07:08:34
And do not forget to tie the lift arms down. Then you can use the tractor lift lever to raise the loader.
Farmered
10-02-2005 05:58:02
The 8N has a pressure port on the pump cover. It is located behind the right step plate about where your right heel is when you are driving the tractor. It is easy to ID because it sticks out at a 45 degree angle You can use this to power a remote valve by putting a return back in at the tranny fill plug. You won't be satisfied because it is very slow.The only sucessful way to run a loader on an 8N is with a crankshaft driven front pump or a P.T.O. pump Ed
Midwest redneck
10-02-2005 04:43:55
Hello just Bill, I am just a redneck. Anyway, What size ports do you have on the machine? Do you have steel tubing? Do you want to make a custom setup?
