Tractor Talk Discussion Forum
Wheel Seal -w- felt
Scott Bartlett
08-22-2005 16:21:21
I have old wheel seal on a 1948 tractor that appear to be two pieces with felt type material in the middle. Can the be repaired or must I find replacements....
Scott bartlett
08-23-2005 09:10:27
 Re: Wheel Seal -w- felt in reply to Scott Bartlett, 08-22-2005 16:21:21
I appreciate all the responses to my question. I was able to take apart the seal and I"m going to cut some new material out of a winter boot felt liner. I will post at a later date and let all know how it works. Thanks again
Uncle
08-23-2005 04:12:19
Scott, Once I was in a bind with a newly acquired trailer (circa 1949) and needed to leave on a Sunday on and 1600 mile trip, I took the seal pieces apart, stacked up several layers of artists/craft felt, (yes the kind your wife and daughter cuts stuff out of) cut it the size of the seal, placed it in the seal and then the seal was assembled, took a pipe a little smaller than the shaft, sharpened it some with a grinder, stood the pipe up on the seal on a steel plate ( so it would cut the felt centers out)and smacked it with a hammer, installed the seal, enjoyed the trip ( worried all the way)I don't use the trailer much now, but it still has that repaired seal and I still have a pair of new seals to install someday in my spare time. moral of the story..... ..... it could be done, select materials to suit yourself, and don't let the experts make you feel small. If it's only axle grease, why the heck not!, If it's gear oil, uh, well , different story..Hey good luck!
Bob
08-22-2005 16:40:46
Why not post what tractor you're working with?
Most felt seals are NLA, but there's almost always a rubber lip seal to replace them, but we'll need to know the application, the number on the old seal, or the dimensions.
This ain't mindreading 201!
