Tractor Talk Discussion Forum
Head not separating
DCM
07-12-2005 21:57:22
Trying to lift a head of a 4 cyl. MH44 gas engine,seems to bind at the front, is it possible that its rusted onto a dowl pin? Trying to be gentle with it so nothing breaks,any thoughts? Dan in AB
J. Schwiebert
07-13-2005 02:17:09
 Re: Head not separating in reply to DCM, 07-12-2005 21:57:22
Have not had one off in 20 years, but there are 2 if I remember small bolts in the area of the thermostat housing that need to be removed also. I have also seen guys break those heads if they did not do that,
DCM
07-13-2005 05:58:01
 Re: Head not separating in reply to J. Schwiebert, 07-13-2005 02:17:09
Howdy JS,I have the nuts off those 2 bolts and have juiced them thinking there may be rust around them,it seems the haed does not want to come over them,Dan.
weaktruk
07-12-2005 23:03:26
Try some PBblaster,24 hrs. and soft face mallet. Your right, be gentle.
bo
07-13-2005 04:28:24
 Re: Head not separating in reply to weaktruk, 07-12-2005 23:03:26
make sure all the bolts are out and if can turn over, crank it...the piston pressure will pop it.
txgrn
07-13-2005 06:06:21
 Re: Head not separating in reply to bo, 07-13-2005 04:28:24
Now THAT is a great idea.
DCM
07-13-2005 06:01:47
There is one bad hole so she does not turn.Will take more gentle effort I guess.Dan
Illinois Boy
07-13-2005 12:52:03
 Re: Head not separating in reply to DCM, 07-13-2005 06:01:47
This may be a bad idea, but - how about putting her in gear and pulling the tractor just enough to turn over the motor... ?????
... or would that damage the block??
Seems to me you'll have to get the stuck piston out of that hole somehow....
DCM
07-13-2005 15:06:15
 Re: Head not separating in reply to Illinois Boy, 07-13-2005 12:52:03
I will have to do that but I want to lift the head off first. Its still giving me a hard time. Dan
T_Bone
07-13-2005 16:19:17
 Re: Head not separating in reply to DCM, 07-13-2005 15:06:15
Hi Dan,
I would soak it in vinegar as vinegar disolves rust, about 24hrs to 48hrs, and turns it into iron oxide, a black goo that will wash off with water.
Me, I would looking for a bolt I missed some where.
T_Bone
